Old 11-12-2012, 07:42 AM   #1
Originally Posted by tyrone_yaris View Post
So if its below 18 shld I presume its a plugged fuel filter?
Yes
Old 11-12-2012, 07:49 AM   #2
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
Yes
Thanks will keep you updated.......
tyrone_yaris is offline   Reply With Quote
Old 11-12-2012, 05:54 PM   #3
seth_man
seth_man's Avatar
Drives: 08 Liftback
other way around, less than 14.7 would be rich and above 14.7 is a lean mixture, cold start air fuel ratio on our cars running properly near freezing should be in the low 12's and will vary a little with ambient temperature
seth_man is offline   Reply With Quote
Old 11-12-2012, 06:31 PM   #4
Yeah - That's correct - I must have been half asleep when I posted that this morning. 13.8 (which is rich) is the AFR that the ECM targets during cold start. 18 (which is lean) is actually the AFR seen during DFCO.
toyota yaris sedan, missing flap just inside fuel filler neck 41magmag41 General Yaris / Vitz Discussion 3 10-17-2010 05:43 PM
typicaljawaiian '09 Yaris Sedan (Cold Country, Big Island) typicaljawaiian808 Hawaii 0 10-15-2010 09:16 PM
