Old 11-12-2012, 09:38 AM   #1
60/40 to Bench Seat Swap Issue
This weekend I drove/ferried down to Long Island for the awesome opportunity to trade Crashy #2's rear bench seat for AuxMike's 60/40 rear seat. I know it sounds like a crazy deal from his stand point, but his reason for wanting the bench was that he purchased a set of Katzkin leather seat covers, and opposite the Clazzio ones, the Katzkin ones are made for the bench only.
Mike and I were in communication before hand to verify that there would not be issues with the swap. People on here have swapped 60/40's in place of benches with only needing to pop some plastic covers over existing holes and punch a couple holes in the carpet. But, since no one has gone in the opposite direction, Mike wanted to be absolutely sure that he wouldn't have any issues. As it turned out, he was correct in being concerned.
We both pulled our rear seats ahead of time. My concern was stuck bolts, and in my case one of the rear most bolts turned a couple of revolutions and then the star portion of the head sheared. I couldn't get a wrench on what was left, so I ended up welding a 17mm nut to the bolt and then I was able to crank it right out.
After removing the seats we shot pictures of the mounting holes to compare. All of the seat mounting holes were present on both cars, but Mike noticed that his car lacked the two holes where the buckle portions of the seatbelts mount to the floor for the bench seat. With the 60/40 the buckle portions mount to the seat frame, rather than to the floor.
Here is how the buckle portions were mounted to the floor on my bench seat equipped car:
Here is Mike's floor with no holes present where the seat belts are mounted on mine:
At this point it was looking like we were going to have to cancel the swap, but then I put my 09, which has a 60/40, on the lift and noticed that even though it lacked the hole in the floor, that there was a nut and plate welded to the floor below that area. Mike took a look under his and snapped this picture of the nut:
I made a template off my bench seat holes and headed to Long Island with a drill in hand. I marked the floor of this car using the template and drilled a small test hole. Sure enough I could see the bottom of the crown nut through the hole, so drilled the hole to proper diameter and we bolted the seat belts in place.
I doubt that another swap like this will ever occur, but in the event that it does, it is now documented.
Old 11-12-2012, 10:12 AM   #2
Quite a few people have wanted to upgrade to the 60/40 seat, and the bolt issue was documented. I'm glad you posted it with some pictures and a very clear description of how to fix it.
Old 11-12-2012, 11:50 AM   #3
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Just curious, where are the the seat belt buckles mounted on cars equipped with the 60/40 seat?
Old 11-12-2012, 02:55 PM   #4
In order to facilitate the fore/aft sliding function of the 60/40, the belts are mounted to the seat frame. This was mentioned in the first post, hence the primary reason for this thread.
Old 11-13-2012, 02:22 AM   #5
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Thanks Wee. I totally forgot that those seats slide, too!
Old 11-12-2012, 11:51 AM   #6
Jason@SportsCar
That could have so easily gone wrong... Drilling that hole right on the money and not messing up a thread in that cap screw. Nice work. I would not have been that confident, I would have taken a spare nut and bolt.
Old 11-12-2012, 12:25 PM   #7
^ That's because he's CTScott.
Old 11-12-2012, 02:44 PM   #8
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Accept no substitute!
Old 11-12-2012, 12:33 PM   #9
I am installing the 60/40 in my car this morning and found that the holes that I was guessing would be used are not all the ones that are actually used.
It turns out that besides the three front most ones, that are mentioned in one of the DIY threads, that there are two additional ones for the inside front track bolts. I just realized that there is not a nut behind them, so I have a feeling that those that did the conversion prior just skipped those two bolts. I am actually going to drop the gas tank and weld nuts to the bottom of the floor pan.
Looks like a second thread will be coming with the DIY for installing the 60/40...
Old 11-12-2012, 03:11 PM   #10
sex
sex's Avatar
Drives: 09 5DR
Will you be using OEM nuts? Are you Herculiner-ing Crashy #2 as well since you're down there?
sex is offline   Reply With Quote
Old 11-12-2012, 05:36 PM   #11
This is actually getting very interesting. I will be posting a new thread tonight for the 60/40 install, as I consider it a separate subject.
But, dang this is turning into a project. I dropped the gas tank, only to find a double walled section (with about 3/4" of air space in between) where those other two nuts need to be. I welded two M10 x 1.25 nuts to two large washers and am now thinking that I am going to drill a hole large enough for the nut to fit through, and then I will weld the outer edge of the washer to the inside of the floor.
Old 11-12-2012, 06:38 PM   #12
auxmike
auxmike's Avatar
Yet they go through the trouble and expense of putting "invisible" nuts in my car knowing that they will NEVER be used (except by me)....
Old 11-12-2012, 02:33 PM   #13
auxmike
auxmike's Avatar
CTScott IS as knowledgable and handy as we believe him to be. It was great to meet the man himself. He made a nice template and found the hidden nuts under the sheet metal first try! He used a special stepped drill bit to do the job. This was an even swap. No $ changed hands. Heck, he spent enough on the ferry ride and I got labor out of him when the Dr. Drilled the hole AND installed the seatbelts. Thank you SO much!
Old 11-12-2012, 02:42 PM   #14
auxmike
auxmike's Avatar
As a footnote always research a project to death BEFORe you set out to do it.
Old 11-12-2012, 03:00 PM   #15
Exactly the same thing that happened to me. Back left. Couple of turns, then the star sheared off.
Old 11-12-2012, 06:40 PM   #16
auxmike
auxmike's Avatar
Worst case scenario; weld the seats straight to the unibody:s
Old 11-12-2012, 11:43 PM   #17
nookandcrannycar
Attachment 49022
Attachment 49018
Attachment 49019
Attachment 49020
Attachment 49021
If anyone ever wants to trade (like AuxMike did) or sell their 60/40 seat (to reduce weight, or for any other reason) please PM me. I am a bench seat owner who wishes to become a 60/40 owner. I realize the beginning of your last sentence is probably true, but one can hope and put his or her two cents in just in case .
Old 11-13-2012, 08:13 PM   #18
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Did you seal the hole afterwards with anything?
Feeler: Swap my hatchback 60/40 rear seat for your solid two piece bench rear + cash auxmike Items for Sale by private party 12 11-11-2012 07:52 PM
60/40 split rear seat swap question jayeh Cosmetic Modifications (Exterior/Interior) 12 10-28-2012 03:07 AM
Rear Bench Seat Question Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 2 10-04-2012 06:44 AM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
Seat belt swap N2scouting DIY / Maintenance / Service 0 07-31-2009 12:51 PM
