![]() ![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
I think you did an excellent paint job! I personally do not like my air vent colors painted; however, to each their own. About your problem, did you sand all the pieces down? Not all paint can be used on plastics due to coating.
#2 | |
![]() ![]() Drives: Racin' yaris :D Join Date: Nov 2012
I dont remember, I'll come back with the full name when i'll post the other photos |
Correct me if I'm wrong, but I believe if you use fine coarse grit sand paper (1500, 1700, or 2000), you can keep the texture as long as you do not rub the same area with all your might. If you're using paint that does not specifically say that it'll bond to plastic, you have to prep it beforehand by sanding - it allows adhesion. After sanding it down, prime it and then use your selected paint.
| new job sacrifice | p123456789 | Off-topic / Other Cars / Everything else Discussions | 19 | 03-02-2011 10:45 AM |
| First Wax Job Completed! | YarisOwnersDad | Wash, Wax, Detailing, Exterior Repairs | 12 | 09-12-2010 06:00 PM |
| Any one in Indianapolis know of a good job for a computer tech? | CtrlAltDefeat | Great Lakes | 15 | 10-28-2009 01:16 AM |
| New Job! | alhope34 | Off-topic / Other Cars / Everything else Discussions | 8 | 09-07-2007 09:07 AM |
