Old 11-13-2012, 12:44 PM   #1
TrYaris
TrYaris's Avatar
Drives: Racin' yaris :D
Originally Posted by MyzticZ3r0 View Post
About your problem, did you sand all the pieces down? Not all paint can be used on plastics due to coating.
I didnt sand all the pieces, my dash have a texture that I like I was afraid that if I sand it, i'd loose it. I'll post some pictures of the problem later today.
Originally Posted by david_827 View Post
beautiful... what brand paint did u use?
I dont remember, I'll come back with the full name when i'll post the other photos
TrYaris is offline   Reply With Quote
Old 11-14-2012, 05:15 AM   #2
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
Correct me if I'm wrong, but I believe if you use fine coarse grit sand paper (1500, 1700, or 2000), you can keep the texture as long as you do not rub the same area with all your might. If you're using paint that does not specifically say that it'll bond to plastic, you have to prep it beforehand by sanding - it allows adhesion. After sanding it down, prime it and then use your selected paint.
MyzticZ3r0 is offline   Reply With Quote
new job sacrifice p123456789 Off-topic / Other Cars / Everything else Discussions 19 03-02-2011 10:45 AM
First Wax Job Completed! YarisOwnersDad Wash, Wax, Detailing, Exterior Repairs 12 09-12-2010 06:00 PM
Any one in Indianapolis know of a good job for a computer tech? CtrlAltDefeat Great Lakes 15 10-28-2009 01:16 AM
New Job! alhope34 Off-topic / Other Cars / Everything else Discussions 8 09-07-2007 09:07 AM
