Old 11-13-2012, 05:36 PM   #1
I'm sorry I missed it too. $1400 sounds excessive for that job.
Did you also buy a new flywheel? Did they resurface yours?
If you are rev'n above 3k consistently while shifting you are being hard on the clutch.
That's just not so. RPM has little to do with whether a clutch lasts or not. I could beat up on a clutch and make it die and never go over 2500. Downshifting, and upshifting aggressively, or constant feathering, will have far more immediate effects than smooth shifting at higher rpms. That's my $.02
Old 11-13-2012, 07:09 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
agreed...on all of it. As many know I turn my rpms between 4500-6000rpm on a regular basis and even with the OEM clutch and 8-10psi of boost when I pulled my clutch/flywheel at 74k they both still looked great. $1400 to me sounds like a clutch, flyhweel, and tranny swap in a lot of places.
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Worn or bad clutch? Tonavi DIY / Maintenance / Service 6 04-27-2009 09:11 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
