Old 11-14-2012, 06:55 AM   #1
DevilGirl
Drives: 09 3dr LB MT
Originally Posted by nookandcrannycar View Post
Did you have an independent shop do it, or a Toyota dealer?
It was a Toyota dealer. We got quotes from both the dealer ($96/hr) and from an independent shop ($99/hr). So in this case the dealer was actually cheaper.
It was a 9-hour job due to having to drop the K-frame.
I'm sorry I missed it too. $1400 sounds excessive for that job.
Did you also buy a new flywheel? Did they resurface yours?
TRD clutch kit assembly was actually cheaper than the OEM clutch as you would have had to buy the parts seperately for the OEM. The part was $347, ordered through the dealer.
They resurfaced the flywheel, which had to be sent out to a seperate machine shop ($100 for that).
So the breakdown is this:
clutch kit assemly - $347
flywheel resurface - $100
labor - ($96 x 9hrs) - $864
total - $1311 (add tax on top of that, total was a lil under $1400)
As for what made the clutch go bad, there were several factors:
- first car I've ever owned that's manual
- relearning to drive stick (originally learned on a '88 Wrangler about 3 years prior to buying this car, but not touching stick between the 2 occassions)
- over 92,000 miles
- vast majority of those miles from my commute
- my commute frequently involving driving in Philadelphia traffic in the afternoons (morning drive in would be fine, but afternoons were a bear)
- the route out of Philly involving a highway merge going up a hill with slow moving traffic
That being said, I have since adjusted my route out of Philly for the days that I drive all the way in to avoid that highway merge section. I know see more traffic lights, but I am usually able to time the lights so that I'm only slowing down rather than stopping at most of them. I'm also a lot better at driving stick than I was when I bought the car.
I think that covers just about all of the questions...
Old 11-14-2012, 11:12 PM   #2
nookandcrannycar
- over 92,000 miles
Thanks for the information . If the hill was steep enough, I would think the last reason you stated might have contributed the most to the demise of the ciutch.....unless you had a REALLY harsh 'readjustment to a manual' period of time.
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Worn or bad clutch? Tonavi DIY / Maintenance / Service 6 04-27-2009 09:11 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
