Old 11-15-2012, 12:44 AM   #1
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
This morning I started the car and it started fine........strange. I did not wait 20 secs or pump the gas pedal. Although I switched it to acc and waited a few secs. Will check again this evening after work when the car will have been parked for about 8 hours and see.
Was there something choking the fuel filter that passed through or something?????
tyrone_yaris is offline   Reply With Quote
Old 11-15-2012, 08:11 AM   #2
It is possible that whatever was blocking it dissolved or got washed off by the fuel sloshing in the tank.
Old 11-15-2012, 08:23 AM   #3
tyrone_yaris
Hmmm...can I use a fuel system cleaner? The ones they put into the fuel tank like Liquimoly or will they be harmful in the long run?
Old 11-15-2012, 11:12 AM   #4
A fuel system cleaner won't hurt, but likely also won't help much. If there is stuff in the tank that was plugging the filter, but eventually washed off, i may still be sitting in there and may repeat the plugging. It may not be a bad idea to eventually drop the tank and clean it and the filter. I just pulled the tank out of one of my Yaris this week, so I could do some welding above it, and it really is not that much work to do.
Old 11-16-2012, 12:46 AM   #5
tyrone_yaris
Wow...thanks I can ask my mechanic to do that for me then. Can the fuel filter also be cleaned instead of replaced? I thought it had to be replaced.
Old 11-16-2012, 07:25 AM   #6
It ideally should be replaced. It is a mesh pad, so while I had mine out I blew it out with the air compressor.
Old 11-16-2012, 07:32 AM   #7
tyrone_yaris
Ok; thanks for your kind help. Really appreciate it.
toyota yaris sedan, missing flap just inside fuel filler neck 41magmag41 General Yaris / Vitz Discussion 3 10-17-2010 05:43 PM
typicaljawaiian '09 Yaris Sedan (Cold Country, Big Island) typicaljawaiian808 Hawaii 0 10-15-2010 09:16 PM
