A fuel system cleaner won't hurt, but likely also won't help much. If there is stuff in the tank that was plugging the filter, but eventually washed off, i may still be sitting in there and may repeat the plugging. It may not be a bad idea to eventually drop the tank and clean it and the filter. I just pulled the tank out of one of my Yaris this week, so I could do some welding above it, and it really is not that much work to do.
#2 | |
![]() ![]() Drives: Toyota Vitz 2007 facelift Join Date: Jan 2012
It ideally should be replaced. It is a mesh pad, so while I had mine out I blew it out with the air compressor.
Update:
Just wanted to update for the benefit of those who contributed and others who may read my post.
The other day while talking to my car electrician he told me that he was 99% sure, in his experience that its the starter motor that probably has to be serviced/repaired. So he told me to lets give it a try before going for the expensive fuel filter replacement. When he removed that starter (which was a pain) as its right under the airfilter box, infact at the bottom. Not much space. The bushes were cut and had to be repaired and also the inner spindle was loose. (Forgive me but I'm not familiar with the technicalities :-p) Anyways, he cleaned up the whole thing and after getting the bushes repaired, he fixed it back and now that sputtering problem at startup seems to have vanished so far, 3 days down the line since he did it.I remember on my 1st Gen vitz too he solved a similar problem regarding startup where he diagnosed the armiture was damaged and needed replacement including the bushes in the starter.... which resolved that problem too.
#6 | |
| toyota yaris sedan, missing flap just inside fuel filler neck | 41magmag41 | General Yaris / Vitz Discussion | 3 | 10-17-2010 04:43 PM |
| typicaljawaiian '09 Yaris Sedan (Cold Country, Big Island) | typicaljawaiian808 | Hawaii | 0 | 10-15-2010 08:16 PM |
