Old 11-19-2012, 07:25 AM   #1
MyzticZ3r0
If you hit the steering wheel hard at some point, you may have bent the sheet metal frame, which acts as the horn switch. In the picture below, with the airbag removed, the frame around the airbag is the piece I am talking about. The other possibility is that if you recently installed cruise control, you may have not properly aligned one of the bolts when reinstalling the airbag.
Thanks for the quick response CTScott! I assumed just bending the sheet metal back to its original form will fix the problem? I haven't installed cruise control, but because I found these forums, I want to change quite a bit in my Yaris .
MyzticZ3r0 is offline   Reply With Quote
Old 11-19-2012, 07:34 AM   #2
If the metal frame is bent, you should be able to bend it back into shape. There are also some plastic pieces that act as insulators, and one of them may be broken. If that is the case, they would not be considered replaceable by Toyota, but they actually just bolt in. I have a complete horn switch assembly if you end up needing parts.
Old 11-19-2012, 08:15 AM   #3
MyzticZ3r0
Thanks, I will look into it probably after thanksgiving - lacking a horn in Vegas is terrible :(
Old 12-14-2012, 02:40 AM   #4
dgche8
Drives: Yaris
Is there a part number for those insulator/tensioners? My girlfriend hit her steering wheel pretty hard. I disconnected the battery and waited about 5 minutes. I dismantled the steering wheel cover and noticed this plastic insulator/tensioner was cracked and teeth were broken off causing the horn to sound constantly. After after of searching this is the only thread I've found that even mentions that small piece. Need help!!!!
Thank you in advance!!!
dgche8 is offline   Reply With Quote
My horn install... Goose DIY / Maintenance / Service 7 01-29-2016 04:10 PM
Transfer truck horn and compressor coheed Items for Sale by private party 5 12-28-2011 08:26 PM
where is my horn located? 2007 3 door Suey 1958 General Yaris / Vitz Discussion 6 11-27-2011 09:57 AM
Toyota Premium Horn Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 22 02-18-2009 11:28 PM
