Old 11-20-2012, 03:16 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I would check your belt tension but it shouldn't make more audible noise.
That raises a question... is there any such thing as inaudible noise?
Old 11-20-2012, 03:58 PM   #2
DJYojimbo
Drives: 2012 Grey Toyota Yaris SE
Can u record the video? Maybe Garm can confirm if its normal or not
DJYojimbo is offline   Reply With Quote
Old 11-20-2012, 05:21 PM   #3
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Audible just means that it can be heard by human ears, so yes there are inaudible noises, and dogs can hear sounds we can not.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
pulling the AC belt pulley on front of compressor yaris9876 DIY / Maintenance / Service 6 07-19-2012 10:12 PM
Squeaky belt after pulley install? Black_griffin6 DIY / Maintenance / Service 12 07-01-2012 10:17 AM
Belt noise? Cutie Pie #2 DIY / Maintenance / Service 20 05-22-2009 01:51 PM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 12:12 AM
Underdrive Pulley Belt ruimond Performance Modifications 11 02-14-2009 09:05 AM
