![]() Drives: Blue 2dr. LB Join Date: May 2010
Powering rearview mirror.
Just wondering if anyone could tell me where a good source is for wiring up a rearview mirror with self-dim, compass and temp. All I need is a 12 volt pos. source and a 12 volt pos. switched source. I see a lot of info. for wiring up a remote start and/or alarm just not sure if I should use the same info. or not? Thanks in advance for any help.
#2 | |
Thanks for the reply CTScott. I'm looking at your remote start wiring guide pdf and curious as to which ignition wire is better to tap into for a switched output, ignition #1(green) or ignition #2(pink)? Thanks again for your assistance. Also I take it I don't really need to consider the accessory(white) wire, correct?
#4 | |
| DIY: Adding LED turn arrows to side mirrors | my2sense | DIY / Maintenance / Service | 10 | 05-28-2012 02:16 AM |
| Rearview Mirror with map lights | Yari213 | Cosmetic Modifications (Exterior/Interior) | 5 | 08-06-2011 07:18 PM |
| DIY: LED side mirror installation | eTiMaGo | DIY / Maintenance / Service | 85 | 06-24-2011 11:48 AM |
| Replacing Rearview Mirror for Smaller One | molinee | Cosmetic Modifications (Exterior/Interior) | 7 | 11-06-2008 10:56 PM |
| Rearview Mirror Too Big? | molinee | General Yaris / Vitz Discussion | 23 | 11-06-2008 03:17 PM |
