Old 11-25-2012, 07:00 PM   #1
Originally Posted by Machinist View Post
Thanks for the reply CTScott. I'm looking at your remote start wiring guide pdf and curious as to which ignition wire is better to tap into for a switched output, ignition #1(green) or ignition #2(pink)? Thanks again for your assistance. Also I take it I don't really need to consider the accessory(white) wire, correct?
For IG switched, I prefer the pink wire. Correct that you don't need the accessory one, unless you want to have it powered with the key in the ACC position.
DIY: Adding LED turn arrows to side mirrors my2sense DIY / Maintenance / Service 10 05-28-2012 02:16 AM
Rearview Mirror with map lights Yari213 Cosmetic Modifications (Exterior/Interior) 5 08-06-2011 07:18 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
Replacing Rearview Mirror for Smaller One molinee Cosmetic Modifications (Exterior/Interior) 7 11-06-2008 10:56 PM
Rearview Mirror Too Big? molinee General Yaris / Vitz Discussion 23 11-06-2008 03:17 PM
