![]() ![]() ![]() Drives: Yaris Hatchieback Join Date: Jun 2010
battery light on and off
I got my alternator replace and the battery light on and off. Battery with 100% good. The vehicle running find but the light is on and off. when the light is on kinda blinking dim. Any idea??? Thanks!!
2007 hatch with 72k now. What else I need to check. Ground cable is good. Autozone alternator is good enough I think. I am going to order one from Toyota. I am going to install it this weekend. Hopefully the solve the problem. Last edited by yariseggvvti; 11-28-2012 at 02:27 AM. |
#2 | |
#3 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
Thanks for you time CTScott and Geoff Peace.
your information helps a bit. I am going to replace OEM Toyota alternator. I hate the light come on the off. It makes me feel annoying. Lucky I purchase the alternator with 28% off the list price. Dont trust any none OEM replacing parts. |
Finally got the factory alternator in now. Running fine and no more battery light on and off. Spend little extra money taking care the problem is worth.
What did you do with the bad one? I'd like to take a look at one of the aftermarket ones to see why the heck they all act this way.
Next time go to the on line junkyard and get an OEM part.with 30k miles on it.
The alternator, water pump, calipers, master cylinder, exhaust system and in fact everything but the MAF and brake pads/shoes on my sons 2000 ECHO with ~180,000 k miles on it are origional.
I return it back to Autozone. I am using it for about two weeks.
![]() Drives: 2007 Yaris Hatchback Manual Join Date: Jan 2011
Reviving an old post because I have a similar issue. I have an aftermarket alternator, but it's been in the car (2007 Hatchback) for over a year now with no issues until now. Occasionally, the battery light and airbag light will flash on then off (sometimes just the battery light). When it happens, I can hear a difference in the load on the engine (slight, but it's there). When running, volt meter on the battery reads 14.5v +/- and when not running it reads 13.3v +/-. Could this be the same corrosion issue with the regulator?
#10 | |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
#11 | |
The one I bought had a lifetime warranty, so let me see what I can get accomplished that route, then I'll contact you if I need one CTScott. Thanks!!
There you go - Definitely hit up the lifetime warranty.
#14 | |
![]() Drives: 2008 Toyota Yaris HB Join Date: Mar 2014
I just replaced my alternator (I'm on my fifth one...in about 2 years.) I've replaced the battery recently. I'm getting the battery light, my airbag light and my power steering light on. All 3 lights will go away after awhile, but whenever the power steering light comes on, even going 40mph+ the wheel will lock up, and I can't move it. It's becoming more of a safety concern now. I've also noticed that my headlights will also be quite a bit brighter. I've had the alternator and battery tested in the past week and everything is "functioning" as it should. All the numbers match up to what should be standard. All the mechanics I take it to, think I'm crazy, until I show them the videos I've taken of it happening. I've also recently blown threw a new set of headlights. All 4 filaments were burnt out, but no fuses needed to be replaced. |
#15 | |
Do you have any way of measuring the voltage when the car is running? You can purchase the little volt meters that plug in to the lighter outlet for about $5 on ebay, if you do not. It would be interesting to see what your alternator is putting out. From the behavior you describe it sounds like it may be running over voltage instead of under. Are you are purchasing aftermarket alternators? Also, have you checked the ground straps between the engine and chassis? Since the engine is mounted with bushings, those straps are the only ground for the alternator.
My previous alternator was overcharging by a good bit. From what the mechanics said I was outputting like a good 19volts idling, even more with the accelerator pushed down.
Sadly, these are aftermarkets, since the dealership wants a good $2,000+ to replace the alternator, especially since the one I have is still under a lifetime warranty, but I will definitely get one of those meters, and see what happens when the battery light is on, and what not. I've not checked the straps, as I didn't think of that possibility. Thanks for the ideas and input! I'll keep you guys posted. Last edited by Miryai; 03-21-2014 at 12:32 AM. |
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
Another return of an old thread.
My 07 hb has the battery light on. My output is 13.5-13.8 with the fan, brights, emergency flashers, radio and defroster. The battery is 12.8V. The battery indicator does flicker every 5-7 seconds. Battery is new as of 1/14. I cleaned the ground & ground on the inner fender. Also cleaned the positive connection. The humidity here is high and is raining & will be until Sunday. The car was purchased 2/14 and I have no history. The dealer did do an inspection in February. Ideas/thoughts? Steve |
#18 | |
| DIM battery light | 2o6 | DIY / Maintenance / Service | 9 | 11-22-2012 06:58 PM |
| Toyota Yaris Battery Light On - Repair | gabo | General Yaris / Vitz Discussion | 1 | 08-24-2011 07:21 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
