Old 11-28-2012, 09:26 PM   #1
DJYojimbo
Drives: 2012 Grey Toyota Yaris SE
How many ft lbs is it supposed to be?
DJYojimbo is offline   Reply With Quote
Old 11-28-2012, 10:40 PM   #2
There isn't a torque measurement for a belt, but rather a deflection and a tension measurement. They point to check is half way between the alternator and the crank pulley.
Deflection:
New belt 7.0 to 8.5 mm (0.28 to 0.33 in)
Used belt 11 to 13 mm (0.43 to 0.51 in)
Tension:
New belt 539 to 637 N (55 to 65 kg, 121 to 143 ld)
Used belt 245 to 392 N (25 to 40 kg, 55 to 88 ld)
Old 11-28-2012, 10:47 PM   #3
frownonfun
frownonfun's Avatar
Deflection:
Tension:
Yeah it's funny I called my service dept to ask them if they can measure the deflection for me and they said there's no way to measure it. They also said that because there's no tensioner that I wouldn't need to worry, it will tighten itself. I seriously wonder if I should be letting these people do my oil changes, even if it is free.
I crush you like tiny clown car, because you are clown, yes?
pulling the AC belt pulley on front of compressor yaris9876 DIY / Maintenance / Service 6 07-19-2012 10:12 PM
Squeaky belt after pulley install? Black_griffin6 DIY / Maintenance / Service 12 07-01-2012 10:17 AM
Belt noise? Cutie Pie #2 DIY / Maintenance / Service 20 05-22-2009 01:51 PM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 12:12 AM
Underdrive Pulley Belt ruimond Performance Modifications 11 02-14-2009 09:05 AM
