#1 | |
Who said Yaris was slow?
Wrong! you have to keep the overall diam of your tire. Meaning that low profile tires are for bigger rims. If you just want a little drop to close that fender gap, you should go for the Tanabes NF's not the DF's or the TRD springs (more $$$) . Those are just 1" drop. Regarding the strut bar... it depends on the way you drive and the roads you have there... You won't feel a difference driving on straight line or on your daily commute. |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
Then why do you have a tire that is so much smaller than the stock diameter? 205/55R15 would have been almost dead on
The diff is close to 3% (not remember exactly)... according to a tire size calculator.
Not sure if has anything to do with this tires (Hankooks RS-2) but when you put them side to side with the OEM alloys on the OEM Potenzas you CAN'T notice a difference in height. It might be there but I can tell you is minimal. atticusrex, on the first post mention a 1" drop by reducing tire profile... that's something else. |
| tanabe nf210 vs. TRD lowering springs?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 01-23-2012 11:00 PM |
| Lowering Springs - Questions ~ AGAIN ~ | jaspie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 01-16-2007 12:23 AM |
| Lowering Springs - Questions ~ | jaspie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 01-10-2007 08:21 AM |
| TRD lowering springs' and/or shocks' Ride Quality?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 08-29-2006 12:42 PM |
| Will putting new lowering springs damage original shock absorbers in the long run? | Joel Leong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 06-07-2006 08:30 AM |
