Old 12-05-2012, 01:09 AM   #1
ljming99
Drives: Yaris '06
The front lower arm is most likely damaged as well since the caster is out, i did a replacement on my previous fwd car and an alignment check...it did fix the caster angle.
Front toe angle is the easiest fix for any shop that does alignment for a living, pretty much adjusting 1 nut.
Since you mentioned that you hit something on the road, I also suggest to do other checks on the suspension as well, like the anti roll linkages too.
ljming99 is offline   Reply With Quote
