Old 12-05-2012, 01:39 PM   #1
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Yeah Jason you can force it but it naturally like locks about 20mm+ out.
Deathbeard again my question is, when driving, when would your suspension ever be this unloaded? Are you jumping? Even on large bumps, the weight of your car is not going to travel against gravity that much to cause your springs to be fully unloaded.
Old 12-05-2012, 01:42 PM   #2
Jason@SportsCar
That should be an easy fix... Back the mount all the way out of the shock, cut the unneeded thread off, back the jam nut off to clean the cut threads, reinstall at lower height. If you need it to be even shorter you could find a thinner jam nut, there is not much of any load on it, or even just ditch the jam nut and go with loctite. With no spring on the shock there should be very little twisting force, and if the upper mount is tight it should not spin.
Old 12-05-2012, 05:35 PM   #3
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Can't say but I wouldn't risk it as it would be catastrophic at highway speeds, also certain driveways and lots of articulation can also make it pop out, megans kit has alot of improvement needed imo
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 12-05-2012, 06:25 PM   #4
1.5
Form>Function
1.5's Avatar
I havnt had a problem at all yet. My fat ass keeps my springs tight lol There are always high tensile zipties
need help on megan coilovers chexmix Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 01-26-2016 04:13 AM
who got megan coilovers walt101786 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-04-2011 07:55 PM
Megan Coilovers $550 including install!!! Walter Items for Sale by private party 14 09-29-2010 12:01 PM
FS: Megan Coilovers and Megan Axleback Exhaust thebarber Items for Sale by private party 19 04-08-2010 04:06 PM
New springs for Megan coilovers? Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-10-2010 08:59 PM
