Trim Ring depth?
After looking at some members here with trim rings i want em. I measure my 15in stock wheels for a depth of 1.75in, i found a set of 4 on ebay: stainless steel ones for $55 as my local Kragen has only 2in depth and autozone no depth listed but its abs chrome.
Did i get the mounting depth correct? 1.75in.
DARK PHASE OF THE MOON
Drives: 07 liftback Join Date: Apr 2009
I've had aftermarket trim rings on two vehicles. They both made odd squeaking sounds, J.C. Whitney is known to have them.
#3 | |
TRIM HUNTER
Slowy getting there
I never measured the depth but I bought mine from O'Reilly's and they fit perfect!!
![]() ![]() Drives: 2008 2dr Yaris Liftback Join Date: Nov 2012
Hey I don't want to be the guy to revive a long dead thread, but I've found some useful information in relation to trim rings and depth, that maybe some new guys like myself could use. I borrowed this from autoamenity.com.
"The pictures below show how to measure the depth of the recess around the bead area of the steel wheel with a straight-edge and a ruler. Position a straight-edge so it touches the edge of the rim in two places and measure inward to the base of the valve stem. If the recess is 1-3/4 inch or deeper, standard hubcaps/wheel covers and trim rings will fit." ![]() ![]() For my 2008 Liftback, My measured depth on the OEM wheels is 2", but thanks to posts by RedRide and Beef, its obvious that 1.5-1.75" depth works perfectly for their rides. http://www.yarisworld.com/forums/showthread.php?t=39500 http://www.yarisworld.com/forums/showthread.php?t=21816 Personally, I like the look. I'll post picks when I'm done, it may take awhile though. |
I went with 1.5" but more because that is what I found. I have been told that 1.75" is the deepest.
I have never actually measured it myself but in my mind, what difference does a quarter of an inch make as long as they actually fit. you may want to look into center caps as well to complete the look. there are a few different options. I actually thought about colored lug nuts but really didn't know what direction to go other than silver for my car so they stayed stock (and I already had them) |
#7 | |
As for center caps, I haven't had much luck. I've looked up the Tercel one's on ebay, but a lot of them are being sold either individually or used for fairly high prices considering what they are. Most likely I'll get the trim rings and wait a little bit to see if I can snag some Christmas sales for lugs or caps. Even without the caps, yours looked pretty darn slick with the paint job. |
I ended up getting some center caps. if you look farther down on my thread about the trim rings, I ended up getting some from NAPA. they are not meant for the car but seem to worp pretty well and at around $3 each, not too expensive either.
The napa number is 730-2411 if you wanted to get some. they require double sided tape around the inside and a little "love" to get them on. they don't come off though. I thought about getting black lug nuts to go with the car and make them disappear. there again, I'm a bit cheap. |
| Group Buy - True Double Din Radio Trim for Liftbacks (180mm opening) | CTScott | Items for Sale by private party | 259 | 06-08-2011 11:13 PM |
| FS: Garmin GPS Unit w/ ProClip Mounts, 180mm Double Din Trim Piece | IsLNdbOi | Items for Sale by private party | 2 | 08-23-2009 02:37 AM |
| NO YARIS. FS: Engagement Ring with Matching Band | kapo | Items for Sale by private party | 6 | 06-04-2009 02:14 AM |
| Canadian DD trim piece. Can any of you Canadian members get one? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 23 | 12-20-2008 12:52 AM |
| Buying a diamond engagement ring | BMGYaris | Off-topic / Other Cars / Everything else Discussions | 20 | 06-20-2007 09:23 PM |
