Old 12-07-2012, 12:27 AM   #1
on your several world championships winning racing cars?
You must be thinking of someone else, but it sure sounds good!
what about F/R camber e toe values
Sure, negative camber increases the size of your contact patch, on the OUTER wheel. The inner wheel (the one that is losing traction and spinning) is not helped by negative camber. That's why an LSD is so helpful.
Sway bar helps with this goal as well -- I use all three methods together to increase contact patch and grip.
Old 10-23-2013, 06:54 AM   #2
speed1
Drives: vitz rs
So U are using LSD. Which kind? Ways? Currently to turn tight I have to steer and back to steer and back to steer while mid pressing throttle. Can I avoid this trick with LSD? Or I have same understeer than open diff? Does it help brake? When brake in turn u have understeer or oversteer?
.. and the truth comes out!
speed1 is offline   Reply With Quote
TRD 2 way clutch LSD kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-05-2009 11:59 AM
Anyone installed an LSD in their Yaris? Keith Tinari Performance Modifications 15 08-01-2009 11:54 AM
LSD Question PHXDEMON Performance Modifications 14 05-04-2009 10:58 PM
TRD Helical LSD kngrsll Items for Sale by private party 18 04-27-2009 11:16 AM
Is LSD Automatic & Manual Same? maxgil05 Performance Modifications 4 04-24-2009 10:57 AM
