Old 03-27-2007, 04:50 PM   #1
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
The clutch pack can easily be replaced not to mentioned tuned for specific apps.
jdubau55 is offline   Reply With Quote
Old 03-27-2007, 05:38 PM   #2
Dragonacc
Drives: 07 Yaris LB, 70 Mach 1, 84 5.0
Replacing clutch packs is a hassel (and costs money), especially in a FWD tranny. And while tuning for specific applications is nice, who's going to do that with their Yaris?
Dragonacc is offline   Reply With Quote
Old 03-29-2007, 02:46 AM   #3
03Z33
03Z33's Avatar
Drives: TCR10
Originally Posted by ROCKLAND TOYOTA View Post
i only saw the application for the ncp13 and not ours...(NCP91)
Part # DBT-1621 is the correct KAAZ LSD for Yaris/Vitz NCP90/91. This has already been fitted to the Tein USA as well as several other US/Canada cars and makes sense since the stock diff and trans are shared between the NCP10 Echo/Yaris (Mk1) as well as FWD Corolla, Matrix, etc...
Originally Posted by Dragonacc View Post
I prefer helical LSDs over clutch style (Kaaz) because the clutch pack will eventually wear out.
If Quaife made an LSD for our cars that's the route I would go personally.
If you can get your clutch to wear out before it's time to change engines and trans, you are doing something very wrong
The Quaife/Peloquin units don't hook up nearly as well and create way too much torque steer without actually getting the power down to the ground.
Clutch packs WILL NOT need to be changed in the lifetime of any street/track Yaris unless you're purely using this as a track only race car at 100% all the time. The same people that would go through the trouble and cost of upgrading to an LSD in a Yaris in the first place would also be open to rebuilding/adjusting the unit if needed. Admittedly this is not for everyone due to the cost of parts and labor.
Old 03-29-2007, 09:03 AM   #4
Dragonacc
My point wasn't that it would wear out quick, but the fact that it would wear out at all, it's not something I want to deal with. It's been my experience that helical LSDs hold higher power levels than clutch pack units also.
As far as which unit hooks up better I think that's open for debate. I've used both kinds of LSDs discussed here (and viscous units too) and both hooked up just fine.
Or you are making a lot of power, or you keep your cars a long time, but on average you're right, I'll give you that.
