![]() ![]() Drives: '13 Super White SE Join Date: Apr 2012
Where does strut bar bolt to?
Hey guys, sorry the extremely naive sounding question but in installation videos ive seen, read, etc. they all show bolts protruding in the far corners under the hood. I've looked (and maybe I'm missing something) but where how the heck does a sway bar attach in the 12/13? TIA!
you guys are always helpful
#2 | |
Ohhhhh so where the red dots are? [IMG]
[/IMG]
![]() ![]() Drives: Yaris SR Join Date: Sep 2011
I am guessing you will have to remove the scuttle panel to install it too.
Davy |
I was able to install mine without removing anything, but you definitely have to get the car off the ground and have a second set of hands.
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
Dumb question: why did you have to lift the car Scott?
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
The bolt goes through the top of the strut tower, so you have to reach up into the wheel well to get up there to get the nut on. I found it much easier with the suspension unloaded.
#9 | |
now it makes sense, thanks.
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
| Which front bar do you prefer? Strut or Sway? | TitaniumBarbell | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 10-16-2009 11:52 AM |
| Rear strut tower bar problem | mrbond | Performance Modifications | 25 | 09-22-2009 02:32 AM |
| Any difference on Tanabe front Strut Bar VS Unknown ebay Strut Bar? | TitaniumBarbell | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-07-2009 06:58 PM |
| Strut bar - To preload or not to preload that is the question | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-02-2009 09:38 PM |
