![]() Drives: purchasing Join Date: Dec 2006
competition seat harnesses
I work at a MINI cooper dealership, and let me be the first to say how easy they have it when it comes to aftermarket. everything is laid out for them. i've installed a couple clip-in harnesses for customers, and i was really impressed. Now i know the proper way to install a harness, and if it takes me to drill holes into the floor, i'll do it. But does anyone have simple set-up?
#2 | |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
yep, you need a roll bar |
resident senior
Use the back seat seatbelt bolts . Safe-Quip has an easy to remove/apply plate that will attach to your rear seatbelt bolts . Their Harnesses are the best . The have old style (latch) and new style (quick release hubs) . In any color you want . They will even sew patches on if you ask . They are right down the street from me . They have a bunch of very experienced "Young" :) ladies that sew the belts .
See my problem i run into is not the shoulder belts, but the lower two belts. there isn't anything behind the seat to mount too with out drilling.
resident senior
use the car seatbelt mounts or the seat mount bracket bolts
also there should be 3 or 4 lower belts not 2 |
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
well, if you are going to autoX, maybe I am wrong, but are safety harnesses allowed to be screwed into the floorboards? I was thinking that for a full harness and to be approved they needed to be hooked to a rollcage...thats just my lack of info comming from my ass though, I am 'prolly completely wrong.
Im sure it should be stated very clearly where and how the harness mounts in the SCCA rules for each class.
The way mine are mounted are probably against any regulations, but it gets the job done quite well without a roll cage (yet)
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
Yeah that's what I thought too, but I rarely even use the harness nowadays, the regular seatbelt is still fine, and it gets rid of that annoying flashing reminder light.
I will eventually get a roll cage and will be sure to have the harness redone properly
#11 | |
Break'em off some.
Get a harness bar made in the mean time. It should be pretty simple for a shop to design and weld one up for you. Then you can use the harnesses and it will be safer. |
well, i've been through the rule books before on a previous car. there are loops between the rear seatback and seat bottom that i can clip into. it's a little less than a 45 degree angle, which is legal. i can mount too the sheet metal, but i need to use approved backing plates to disperse force better than a nut and washer. Your also not allowed to mount to the seat. i'll have to see about getting some brackets made to use the seat track mounting points.
| DIY - Sparco Race Seat Install | Idjiit | DIY / Maintenance / Service | 16 | 08-14-2017 09:15 PM |
| Back Seat Removal... | Idjiit | DIY / Maintenance / Service | 87 | 02-08-2015 12:07 PM |
| How to install seat covers that require... | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 13 | 09-23-2007 07:57 AM |
| back seat | KSIbucky | General Yaris / Vitz Discussion | 10 | 05-30-2006 12:54 PM |
| Liftback seat question | Goose | General Yaris / Vitz Discussion | 6 | 04-21-2006 12:29 PM |
