![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
before replacing the pressure switch try to jump it and create a false pressure reading. Did this on a Ford F550 once. as long as the yaris is a Normally open switch it should create the false reading.
It is not a switch, but rather a pressure transducer. To bypass it you would need to provide the correct resistance for the pressure you are trying to emulate.
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| 3 Drive Throttle Contoller by NTD | Sabretooth | Performance Modifications | 31 | 10-07-2010 12:12 PM |
| 2006 Yaris Hatchback Replacing Stereo Head Unit help | lauren24 | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 07-01-2010 11:13 PM |
| Req: Head unit suggestions. | xed | In Car Entertainment + Electronics (audio / video / alarm) | 21 | 08-09-2007 07:38 PM |
