Old 12-20-2012, 02:20 AM   #1
SAV912
Pirate Yaaaaris
SAV912's Avatar
Originally Posted by Philspecv View Post
*update* tried this and got it to work. Thanks... Only problem is that my halogen highs don't work properly now..
Do you have aftermarket headlights with separate slots for halogens? If you are using stock housings, the low beam xenon bulb is the same that would be used for the high beam.
The high beam lamp will not illuminate in the cluster because the current is different, but if you have bi-xenon headlights, they should still ignite. If you replaced it with a single bulb xenon kit, there are no highs to ignite and thus you no longer have high beams at all.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
FS:35w HID KIT from REALTEK 8000k wowitswil Items for Sale by private party 4 01-14-2010 02:28 PM
HID Kit ecmiyake DIY / Maintenance / Service 5 12-12-2009 05:21 PM
What is the best HID kit ? waka General Yaris / Vitz Discussion 1 12-03-2009 07:49 PM
To put on PnP HID kit without retrofit, Yes or No? mr.white_hb Cosmetic Modifications (Exterior/Interior) 3 09-20-2009 08:43 PM
