Old 12-27-2012, 07:34 PM   #3
yaris2010RS
yaris2010RS's Avatar
Thanks scott,
Positive terminal on the battery was fine (brand new and tight) and also my ground on the engine (that i had tons of issues due to those not being tight) are good and tight.
I did also check the main power wire from the alt to the battery and found that had been left loose....tfrom the arking it melted the plasic clip cover to protect that connection and corroided the hell out out of the screw. I tried to tighten it but due to corroision it was hard to turn so to ensure i didnt break it. I will hit it with pb blaster when i get back from the holidays and try to loosen it off, clean it and tighten the heck out of it.
Would di-electric grease be okay to put on that connector
Urgently Seeking Help! Yairs Accelaration Issue! 08 Yaris 5 speed! gnava3 DIY / Maintenance / Service 7 08-25-2010 03:55 PM
JDM GROUND WIRE VOLTAGE STABILIZER TOYOTA YARIS jamal1984 Performance Modifications 17 03-26-2007 01:01 PM
