![]() ![]() Drives: 2008 2dr Yaris Liftback Join Date: Nov 2012
Old thread revival, but to address this issue for future center cap experimenters I've come up with a few solutions. First and most easy/perhaps a little ghetto, is to use a plastic zip tie around the out side of the tabs of the the tercel center cap. You'll want to tighten the zip tie until it is close to the shape of a square. The caps will then snugly snap into place. I'm currently using this method.
A safer solution would be to get some metal wiring, 2 or 3 mm diameter should do. Bend it around the center hub to form a circle, and twist and tighten with pliers. This will give your worn out tercel tabs something to grip around, and serves as a makeshift retention ring. |
| FS: Scion Center Caps | jpmck03 | Items for Sale by private party | 1 | 12-31-2011 12:57 AM |
| TOYOTA center caps and Trim Rings for sale. | coffiend | Items for Sale by private party | 10 | 05-11-2010 06:29 PM |
| custom center caps? or vitz center caps | BrazdonW | Cosmetic Modifications (Exterior/Interior) | 2 | 09-06-2009 11:21 PM |
| Toyota center caps | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 04-14-2009 12:43 PM |
| WANTED - Stock 15" 2007 Yaris HUB CAPS! | Chris07LB | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 06-29-2006 07:09 PM |
