Old 01-02-2013, 11:30 PM   #1
JeffRapp
Drives: Flint Mica Yaris Sedan
Question Brake & ABS Light On
My 2007 Yaris just started lighting up the Brake & ABS lights when I drive. I read through the entire post about this issue with the Canadian model, and cleaned and greased the contacts (rear for now, didn't have to time to disassemble the front end).
I got the DTC code from the blinks - 3494. Do I read this as 2 different codes, i.e. 34 & 94? If so, does that translate to "Left Rear Wheel Speed Sensor Signal" and "Control Module Communication Bus OFF?"
This seems to have started after my battery died (winter sucks), and I had to jump. Any chance of that causing the issue?
JeffRapp is offline   Reply With Quote
Old 01-03-2013, 12:48 AM   #2
That is correct that it is two separate codes. Did you try clearing the codes to see if the 94 stays off?
Old 01-03-2013, 11:17 PM   #3
JeffRapp
Short 4 & 13, turn it on and pump the brake 8 times? Didn't seem to work, but I'll give it another shot.
Old 01-05-2013, 12:10 AM   #4
CoryM
Drives: 2009 5-door, 5-speed
Chances are the "communication" DTC is erroneous (and yeah, maybe from low voltage when the battery died). The sensor DTC is probably there for a reason (and will cause both the ABS and brake warning lamp to come on.
ABS and "!" lights are ON again! onizuka Canada 457 04-28-2023 10:40 AM
abs light on brieghne DIY / Maintenance / Service 1 02-23-2012 09:30 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 08:34 PM
Toyota Yaris -06 VCC and ABS light went on? goedafred DIY / Maintenance / Service 4 03-01-2011 01:22 AM
custom third brake light? NinjaPirate Cosmetic Modifications (Exterior/Interior) 3 11-12-2010 02:16 AM
