![]() Drives: Toyota Yaris YRS 2000 Join Date: Jan 2013
Thank you so much for all your great advice!! I know where it is located so will have a look later. When you say a a relay stuck, you mean internally in the alarm, or externally??
Internally. They typically contain a bunch of small relays for controlling the flashing of the lights, honking of the horn, etc. The relay contacts can stick due to electrical arcing, during the switching process. If that happens, giving the relay a good slap will usually free the stuck contact. Once it happens it is likely to happen again, so you want to eventually replace the bad relay.
| Lights don't turn on when I open the hatch | spookybathtub | DIY / Maintenance / Service | 8 | 10-25-2012 12:24 PM |
| Help!!! My tail lights does not turn off. | Yaris_PR | DIY / Maintenance / Service | 7 | 07-24-2012 09:37 PM |
| Solar powered High Bright LED lights replacing the fog lights | alan1828 | Canada | 10 | 05-14-2010 12:34 AM |
| Side Marker Lights | Stoln | General Yaris / Vitz Discussion | 1 | 07-04-2007 02:44 PM |
| Side Turn Signal Lights | bigsky2 | Cosmetic Modifications (Exterior/Interior) | 15 | 08-24-2006 06:06 PM |
