#1 | |
How about the key itself, can a locksmith cut the key or does Toyota have to do that too?
I am not allowed to put anything here because I do not have any ricey mods on my Yaris.... |
#2 | |
Cutting the key can be done by a locksmith without a problem.
Ok, I tried to program my new key today using the above procedure and it's not working. I get to step 9 and the locks cycle once to indicate "add" mode. But after I hold both lock and unlock, then lock. Nothing happens after that. The instructions say that the locks should cycle once if it worked and twice if there is a problem. It does neither for me.
Also, can some one tell me what the different modes are for. Obviously "ADD" means to add a remote? What does "CONFIRMATION", "PROHIBITION", and "REWRITE" modes do? Thanks!
#4 | |
while retaining the previously registered codes. This mode is used when new transmitters are added. If the number of registered codes exceeds 4, the previously registered codes will be erased in order, starting from the first registered code. • Rewrite Mode is used to erase all the previously registered recognition codes in order to register new recognition codes. This mode is used when the transmitter or the door control receiver is replaced with a new one. • Confirmation Mode is used to confirm how many recognition codes have already been registered before any additional recognition codes are registered. • Prohibition Mode is used to erase all the registered codes and disable the wireless door lock function. This mode is used when the transmitters are lost
Thanks CTScott, that helps a lot!
So I am thinking I got the wrong key fob for my Yaris since I cant get it to program at all. Does anyone know what the correct part number would be for a FOB with electronics for a 2007 Sedan?
89070-52860 or 89070-52730
well poop. I bought a 89070-52730 and it wont program. Any suggestions on why the Yaris wont program it? I followed the instructions exactly, tried it like 10 times.
The description says it must be programmed by a Toyota dealer but I am assuming they would just be performing the procedure listed above? http://www.amazon.com/Keyless-Remote...433742&sr=8-1&
| Tags |
| keyless, remote, wireless |
| Keyless Entry stopped working but buttons do work! | worduphomes | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 01-17-2013 09:35 PM |
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
| Keyless Entry Remotes are dead... now what? | Zanutto | General Yaris / Vitz Discussion | 7 | 01-11-2012 05:17 AM |
| I lost my master keyless entry key, need suggestions.... | Frankd1 | DIY / Maintenance / Service | 19 | 12-01-2010 11:13 PM |
| Aftermarket Keyless Entry - How does it affect the Warranty? | aerock19 | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 09-07-2007 02:11 PM |
