guy2can
Oil Pan Drain Valve
2004 Echo RS:
So, with the amount of commuting I do with the car, I wanted to cut down on getting new drain plug gaskets and cut the touch time on an oil change. I installed a Fumoto Oil drain valve (PN: F103S)(12mm-1.25) from Quik Valve in New York. Easy install when you do your next oil change. You can get a white plastic adapter that will attach to the valve and plastic hose to help drain the oil if needed. but I didn't install it as the plastic adapter is hard to remove once installed. Here are some pics of the install. |
I love the Fumoto valves, and have them on almost all of my vehicles. With the position of the Yaris oil pan you would almost like to have a little something to protect the valve.
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jan 2013
i read on BITOG that fumoto valves are prone to leaking. They're an unnecessary risk imo
I can't imagine one leaking. They are widely used on industrial machinery and are incredibly well made ball valves. I can see the cheapo Fram ones leaking, but not the Fumotos.
One thing for sure a properly tightened drain bolt aint leaking if you run over something and it hits the bolt.
You cant say the same thing for a valve. Also you just made it easier for someone bent on doing you dirt to mess with you. Unlikely as that may be...
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2009
I had one of these on mine for a couple of years and didn't have any problems with it. If you hit something high enough and hard enough to damage this valve, it would have a good chance of puncturing the oil pan anyway. I've never hit anything and cracked my oil pan, but I have f'd up enough bolts to think that under tightening or f'ing up the threads on the drain plug would be more likely problems. Both are prevented by using the valve.
The only reason I took it off was that I felt like the valve went into the oil pan a little too far and left a few ounces more oil in it than I was happy with. I plan on putting it back on at some point in the future, altering it in some way so more of the oil drains out. |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
Intresting stuff
Anyone else had experience with these? |
Happy pony pointed out the one reason I removed mine. My plan is to cut some of it off and then seal it upon installation. Just haven't gotten around to it.
Look at the specs for engines and you will see "oil capacity at oil change" and "oil capacity at rebuild".
All engines have some residual oil in them when you drain it to "change" it. My ST1300 holds five quarts but only four come out when you drain the crankcase. So if it bothers you that the drain valves stick in a bit father, you are worried about nothing.
Thanks, and I knew that...but I still worry about nothing alot.
#11 | |
Great!
How often can we fix the problems in our lives?
^^^^ditto. Now that beats cutting.
#15 | |
![]() Drives: 2010 Yaris Join Date: Dec 2017
The broken Fumoto Valve |
Anyone run a piggyback plug? if so, do you have a part#? (2010 Yaris) That may be preferable. Saves wear/tear on drain pan threads and doesn't 'stick out' from the drain pain.
in response to this 5 year old thread:
it's a steel oil pan cover. steel bolt into steel oil pad does not wear out very quickly. a new oil pan cover is $32 if it is a problem you are concerned with, replace the pan every 4 years or whatever. |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
