![]() Drives: Toyota Yaris 2007 Join Date: Nov 2012
Yaris 2007 ABS & Brake light issue after wheel bearing change
Hey guys, I recently changed my Toyota Yaris 2007's rear wheel bearing due to a lot of noise coming from it. After installing the new bearing, the sound is gone, but the 'ABS' and 'Brake' light on the dash show up together from time to time.
I've checked the wheel bearing and the sensor and it's connector was fixed properly, so I'm not sure that what's causing it. Any help would be appreciated, thanks. |
Pop the connector again and hit both sides with some contact cleaner. With it being intermittent it may be that the connector has some corrosion.
Thanks for the reply, but the connector was pretty clean when I hooked it back.
Bummer. The other likely and more expensive cause is the sensor itself being damaged during the bearing replacement. Check the cable too to make sure it didn't get pinched during the process.
Sry for the late reply and yea, I was also thinking the same and there's no actual way to changing the sensor rather than the whole bearing itself which comes with the sensor.
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
