Old 01-08-2013, 11:40 PM   #1
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
But.. if your engine is running it shouldn't stall like that. I actually think it's your alternator. Do a test, start the car with a jump, then disconnect a lead off the battery. If the car dies, it's your alternator gone. If it doesn't, it's your battery.
Old 01-09-2013, 12:05 AM   #2
edmscan
edmscan's Avatar
Drives: 2020 Corolla
Replaced the battery today .. and its all working fine. The battery was totally shot .. the dealership tested it and it was dead. Like really dead.
So .. 121$ later and I am good to go. The battery was the original battery in the car .. so it was 6 years old which around here is amazing life for a battery.
So .. I just hope that the new one lasts that long.
edmscan is offline   Reply With Quote
Old 01-09-2013, 12:08 AM   #3
edmscan
edmscan's Avatar
I will actually go tomorrow to a local business that specializes in batteries and they will test your battery / charging system for free. So .. I will see what they say.
Old 01-09-2013, 03:05 AM   #4
nookandcrannycar
I would have agreed with you 100% on this before my experience with my Yaris (now I would be about 98% in agreement ). I kept my OEM battery until its dying day, literally (and at 138,000+ miles). I wouldn't have made it even another mile. I thought I was going to have to push the car into the bay at Sears (in Texas). 21,000 miles later I had the same symptoms and it tested out to be the alternator (which I assumed it would be). I was in Minnesota, and (coincidentally) Sears had the best available deal.
Old 01-09-2013, 03:13 AM   #5
edmscan
edmscan's Avatar
So are you saying that my alternator is bad ... and it wasn't the battery ? That would really suck .. as well I just got a new battery. The thing is that I drove my car on Saturday (and it was fine, no problems) and on Monday it was dead. I am going to get my alternator (ie charging system) checked later today .. and I will post the results.
Old 01-10-2013, 05:24 AM   #6
nookandcrannycar
No, I meant that before my experience with my Yaris I would have 100% agreed with Betrivent that your issue is a bad alternator, but that my first experience of the 'alternator like' symptoms ended up being the battery rather than alternator. So, I learned that the symptoms CAN apply to either a battery problem or an alternator problem. Whenever I'd had such symptoms on previous cars, the problem had always been the alternator. When I had the symptoms for the second time on my Yaris (21,000 miles later), the problem was the alternator.
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Charging voltage for stock battery Vinceb DIY / Maintenance / Service 3 02-12-2011 12:10 AM
