Old 03-28-2007, 12:34 PM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
There must be a lot of newbies at that stealership because options on Toyotas simply don't work that way. The packages that are listed in the "Build Your Toyota" section of toyota.com are exactly what the dealer can order. The packages can't be broken apart by you or by the dealer.
ABS comes in Option C, which also includes the Power Package. In other words, if a Yaris has power locks then it also has ABS whether or not it is specifically reflected on the invoice.
This means they first car they received for you was exactly what you asked for.
- Brian
Share the Road
Old 03-28-2007, 01:01 PM   #2
Where is my Yaris?
My Sexy Yaris
Where is my Yaris?'s Avatar
Drives: Barcelona Red
See this is another problem. In november when I ordered the car the option said it was Power package with alloy wheels and antilock brakes, i have the print out from the inventory. Now the same option doesn't say antilock brakes. Toyota change the option some time in the beginning of the year. The dealership had to know this.
Where is my Yaris? is offline   Reply With Quote
Old 03-29-2007, 11:42 AM   #3
Pavel Olavich
Drives: 2007 Yaris LB
WRONG....just because the LB has the Power Package does NOT mean ABS too! I have the Power Package on my 2007 LB and I do not have ABS...
Pavel Olavich is offline   Reply With Quote
Old 03-29-2007, 12:39 PM   #4
Where is my Yaris?
My Sexy Yaris
You are right, but the power package i had ordered had abs in it. I have the print out of the inventory where is says it.
Old 03-30-2007, 01:39 PM   #5
Pavel Olavich
No, the Power Package you ordered did not have ABS....you added ABS to your order...there is a difference. ;-)
Old 03-30-2007, 05:00 PM   #6
Where is my Yaris?
My Sexy Yaris
The inventory print out says the name of the package which states it had abs all for one price. It was not separate.
