Old 01-17-2013, 12:46 PM   #1
iacubovici
Drives: Yaris 2008
different ECM
Hello, I want to do this on my 2008 YarisHB, I made the 4 switch assembly, I found the D3 connector but the problem is that my ECM is BOSCH and the A21 plug is different. Is bigger with twice the number of pins and I don't know where to put the wire that had to be in the nr 40 pin on the A21 connector. Any suggestions? And I saw that I have 2 switches on my clutch peddal: on that works when tha clutch is pressed, witch is used to start the car because mine has the Start&Go button, and there is another switch near the stop bolt, so I guess I dont't need to buy this switch anymore.
iacubovici is offline   Reply With Quote
Old 01-17-2013, 12:52 PM   #2
Unfortunately cruise control is not programmed into the ECM of 2007-2011 European Yaris, so this will not work for you. You would need a complete aftermarket cruise control kit, which appear to be very expensive.
Old 01-17-2013, 01:23 PM   #3
iacubovici
Drives: Yaris 2008
I see, 10x for the answer
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
