Never heard of a CDV. What is it?
play every day
Hey bronsin,
![]() I didn't know either and found this on Wikipedia. "A clutch delay valve is an automotive component added to the clutch system of an automobile to standardize clutch engagement speed. Its purpose is to engage the drive train of an automobile without introducing shock to the drive train components by engaging too quickly. By preventing drive train shock, CDVs also prevent an automobile's balance from being upset, which aids in handling characteristics. Clutch delay valves operate on the principle that engagement only needs to occur at a certain rate to be efficient and that engaging at a quicker rate can damage the drive train components of an automobile. Engaging the drive train to the engine too quickly can damage drive train parts, including the transmission, differential half shafts, axles, and CV joints. Engaging the drive train too slowly can damage the clutch friction disc and cause clutch slippage. Clutch delay valves operate as one-way restrictor valves that limit the volume of fluid that can move through the lines in a given time. This ensures a steady quick and firm engagement without being too fast for the drive train to handle since clutches can quickly disengage but re-engagement is damped. The clutch delay valve slows clutch engagement and was intended to reduce drivetrain shock in the event that an inexperienced driver quickly engaged the clutch at higher revs." Greg |
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 03:59 AM |
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 07:14 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
