I stay G'd Up
will it fit?
17x8.5 25mm offset?
![]() I would get the black ones and then slam the car as much as I can. The car is slow so might as well make it look good. |
![]() ![]() Drives: BBM Yaris HB Join Date: Apr 2006
i personally think rim width is too wide, and offset is too low. if it was 17x7.5, offset ~40mm, then you'd be ok. really hard to find a nice wheel with lots of lip in a higher positive offset. they look nice though!
Only Happy When it Rains
From what I've been told here they might not be able to fit over the front brakes, etc.
Colin Chapman disciple |
i dont see why a 17" wheel will have any problems clearing the front brakes
I stay G'd Up
well the rims fit on scions, i was more concerned about rubbing
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback Join Date: Mar 2006
If you want the look of a multi-piece wheel, you should buy a multi-piece wheel. :P
Its the +25 mm part, not the size part.
I doubt you'd have much problems with rubbing.
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Do we know the stock offset on the Yaris? I think it's +40 or +42; I know it's higher than the xB, which is +38.
If you lower the car with a +25, you might have to worry about rubbing. Tirerack.com is recommending +40 and higher for the Yaris. If anyone is in the Milwaukee, WI area, I'd be willing to slap on one of my wheels (+35) to see if it'd rub. |
5 Stars, Bitches
Isn't the offset completely dependent on the rim width? So +40 might be what they recommend for a 7" wide rim, but not necessarily for an 8.5" wide rim.
#10 | |
I stay G'd Up
5 Stars, Bitches
Well, since you're so tactless about your opinion on everyone else's choices I'll just say that they're fugly as all hell and the fact that it's a poser rim makes it even worse. Please don't buy those.
#12 | |
Drives: Red Milano FIT LX Join Date: May 2006
| Power-to-Weight Ratios of Yaris, Fit, Mini, etc. | Idjiit | Off-topic / Other Cars / Everything else Discussions | 6 | 10-06-2017 05:10 PM |
| Thule fit kit for Yaris !!! | lappie | General Yaris / Vitz Discussion | 13 | 09-14-2017 03:29 PM |
| The Honda FIT... | Leenis24 | Off-topic / Other Cars / Everything else Discussions | 198 | 08-09-2006 07:11 PM |
| Yari vs. Honda Fit | nwdixieboy | General Yaris / Vitz Discussion | 78 | 05-24-2006 01:08 PM |
| How will this car do against other subcompacts (Fit, Versa) | Mess11 | General Yaris / Vitz Discussion | 23 | 02-02-2006 11:27 AM |
