Old 01-21-2013, 12:06 PM   #1
yaris2010RS
yaris2010RS's Avatar
Thats kinda what i was thinking also.
i was thinking "Budget build" on a stock, with the stock ECM, A piggy back, and a built motor that can handle and benefit from a higher RPM.
Im hoping to park my Yarii soon and test from that. Im hoping the signal, like the speed signal goes through the ECM and cluster but takes the feedback from the cluster?
Old 01-21-2013, 12:14 PM   #2
Speed goes from the tranny to the cluster and then from the cluster to the ECM for non-ABS cars. And, from the wheel speed sensors to the ABS ECU to the Cluster to the ECM for ABS equipped cars. Either way, you can still have the speedo work while having the ECM not see the speed signal.
Old 01-21-2013, 01:16 PM   #3
yaris0985
Drives: yaris sedan 09
i got a dodge neon 2000 (2gn) on the tranny you have a wire (dont remember the color) is the "Speed sensor" you have to make a extension to inside the car and make a switch ON/Off
that gone make when you hit 180km/h you shut down the switch you pcm think you are at 0km/h and continue to push gas (until you reach 6500rpm)
But you need a GPS, because if you want to put back the switch at ON you pcm gone freak...... because you are over 185km/h, but as soon the switch if OFF your mileage is not added...
if you want go on www.clubneonquebec.com and look for "Pat Tuning"
yaris0985 is offline   Reply With Quote
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Facts of Higher Fuel Octane Yaris TTE JWRC General Yaris / Vitz Discussion 9 01-29-2007 07:16 PM
