Old 01-22-2013, 06:01 AM   #1
bronsin
bronsin's Avatar
Im curious about your "test" here. What exactly are you "testing"? The car will last as long, get as good mpg, whatever oil is in it. If you had two car one with synthetic oil and one with the cheapest dino around, no one would be alble to tell which was which if they didint already know.
As long as you use oil the OM says to, you are good.
Old 01-22-2013, 04:23 PM   #2
Happy Little Pony
Drives: 2007 Yaris HB
That's the problem. You say that the car will last just as long using conventional. And I think that you are correct. And by the way, so does Toyota. It's what they recommend. But how do I prove it?
In this thread you can see that people are scared of conventional oil. Don't use it past 5000 miles. Don't use it past 3000 miles, even. In other words, conventional oil equals BAD oil. I think that this is wrong, and that a modern API approved conventional oil is quite capable of handling the lubrication needs of the 1nzfe up to 5000 miles. And even well beyond that.
So, to test my theory, I'm going to put cheap Mobil Super 5000 in my car and run that oil out past 6000 miles. Then I'm going get an oil analysis performed and see how the oil held up. I can then use this information to make an informed choice about my cars lubrication needs, not just make idle speculation. My warranty is expired. I can do stuff like this now!
And, really, I was going to get one done to see if my new air intake was doing a good job of cleaning. This just makes for a more interesting oil change and offers me some amusement in my otherwise drab life.
Happy Little Pony is offline   Reply With Quote
Old 01-23-2013, 06:10 AM   #3
bronsin
bronsin's Avatar
Tell us what the analysis is when it comes back.
I did my own test of synthetic oil comparing my mileage on my trip from NJ to AK two summers ago. 5200 miles there on conventional oil, 5200 miles back on synthetic. Gas was ~$7 a gallon in northern Canada. Synthetic oil used to claim back in the 70s it increased your mpgs. I needed all the help I could get with those gas bills! (over $100 every day)
It did nothing as far as make the car go farther on a gallon of gas.
You would think if there was anything to the claims its "better" than conventional oil they would take identical cars and run one on regular and one on synthetic until they break.
But they dont. Probably because then synthetic oil would be exposed as just an expensive excercise in mental masturbation.
Old 01-23-2013, 08:15 AM   #4
nookandcrannycar
Was gas any cheaper in Alaska?
Old 01-23-2013, 11:47 AM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I would be interested to know that as well. When I was in Alaska back in 2006 it was roughly the same prices as it was for me in Maine, maybe 10-15 cents less.
Old 01-23-2013, 12:02 PM   #6
bronsin
bronsin's Avatar
Yes quite a bit cheaper compared to northern Canada (Yukon) Here is a picture of a sign in Fairbanks...
Gas in the lower 48 out west at the time was ~$3.79.
Gas in the Yukon was $1.53 a liter which is about $6 A GALLON. bUT YOU HAVE to PAY $1.10 for a Canadian dollar so add 60 cents to that figure...
Old 01-23-2013, 12:58 PM   #7
nookandcrannycar
Good! Was the Alaska part of your trip easy on your Yaris? (as in no dirt roads, no potholes, no dirt roads with potholes, etc. )
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
