Check out my remote start wiring DIY thread for info on installing a remote starter.
http://www.yarisworld.com/forums/showthread.php?t=24860 Are you sure that your car has the immobilizer, as it was not really common on US Yaris until 2009? If you do, then you definitely need a transponder key bypass module. Also, are you sure that you have the factory alarm (you can tell for sure by looking behind the passenger glove box for the presence of a module mounted all the way to the right).
#2 | |
![]() Drives: 2007 5d yaris Join Date: Jan 2013
Do you have a European one in Clifton, New Jersey?
#5 | |
First off: Which engine does yours have (as that makes a difference harness wise)? Is it key start, or keyless start? If it is key start, is the ignition switch all metal or is just the part that turns with the key metal and the outer part black plastic?
#6 | |
| Viper Alarm on a 2009 Yaris | dajinn | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 09-27-2009 12:32 PM |
| Just had installed a Viper 5900 remote starter-alarm system | fazali | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 02-20-2007 09:29 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
