Old 01-23-2013, 03:00 PM   #1
Originally Posted by eeosman View Post
I only could find xpresskit pkall around here. I see several types of t-taps. Which one I should use?
The xpresskit one is fine. For the t-taps, I always buy the 3M ones, but really any will do. In the case of remote starting a Yaris, all of the connections are relay coil side, rather than contact side, so it is all low current.
Did you test the key disabling the alarm?
Old 01-23-2013, 07:00 PM   #2
eeosman
Drives: 2007 5d yaris
I mean what gauge t-tap. Yeah I kill the alarm by pressing the unlock button on my key.
eeosman is offline   Reply With Quote
Old 01-23-2013, 07:03 PM   #3
You will need t-taps for 22-18 AWG wire.
With killing the alarm, you need to test by unlocking the door with sticking the key in the lock, as opposed to pressing the button on the the key. The button press goes through a way that the remote starter will not have access to.
Old 02-14-2013, 09:01 AM   #4
eeosman
Non-remote car key can kill the alarm by unlocking doors. So does it mean that I can connect the oem alarm to the remote start?
Old 02-14-2013, 09:59 AM   #5
I believe so. Also, try getting in, locking the doors, arming the alarm, and then starting it to see if the alarm triggers.
Old 02-22-2013, 10:35 AM   #6
eeosman
It triggers at 'ON' position.
Old 02-22-2013, 11:17 AM   #7
OK. So you would have to trigger the door key signal with the remote starter's "factory alarm disable" output to prevent that.
Viper Alarm on a 2009 Yaris dajinn In Car Entertainment + Electronics (audio / video / alarm) 2 09-27-2009 12:32 PM
Just had installed a Viper 5900 remote starter-alarm system fazali In Car Entertainment + Electronics (audio / video / alarm) 9 02-20-2007 09:29 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
