Old 01-23-2013, 07:08 PM   #1
Sparcoboy
Drives: 2008 XP9 by Sparco
A clutch doesn't wear even a little bit by keeping the pedal depressed, only the throwoutbearing will get some extra wear on it, but on a Toyota they're built strong enough to last the lifetime of the car.
Sparcoboy is offline   Reply With Quote
Old 01-24-2013, 06:35 AM   #2
negev
Drives: Toyota Yaris VVti SR 1.3L 3D
What about keep it up just enough to keep the car stationary on a hill though?
negev is offline   Reply With Quote
Old 01-24-2013, 11:52 AM   #3
peckerhead
Drives: 2007 Yaris hatch
Go ahead and do that. Show us the pictures of your smoked clutch disc, pressure plate, and flywheel in 10,000 miles.
peckerhead is offline   Reply With Quote
Old 01-24-2013, 01:32 PM   #4
Just use the handbrake or avoid driving in hilly areas (I avoided hilly areas until I got confident in using the handbrake on hills).
Old 03-13-2013, 09:16 PM   #5
Kar98
Drives: 2011 Scion tC
Smoke. Lots and lots of clutch turned into lots of smoke. Use your handbrake for hill starts.
Old 01-24-2013, 11:01 AM   #6
peckerhead
Nonsense.
Old 01-25-2013, 12:26 PM   #7
Jabro
Jabro's Avatar
Drives: 2008 2dr Yaris Liftback
Originally Posted by peckerhead View Post
Nonsense.
Peckerhead, mechanically speaking I have to disagree with you. So long as the clutch is fully disengaged, no friction will be occurring whatsoever, equating to zero wear. Having the clutch fully depressed on a neutral incline shouldn't do any more damage than having the car in neutral. Now on an incline, that changes if your holding it at the "sweet spot", because the clutch is no longer disengaged and is encountering friction.
Jabro is offline   Reply With Quote
Old 01-28-2013, 05:28 PM   #8
Kal-El
Kal-El's Avatar
I admit that I never use the handbrake while driving. When stopped on an incline, I'm in neutral with the brakes depressed, and then balance the clutch and gas to proceed from a stop to prevent rollback. In other instances, I ride it briefly while in reverse. I think these practices are normal.
My original clutch works perfect with 132,000 miles on it.
Old 01-29-2013, 11:55 AM   #9
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
That's what I do when stopped on a hill. Thankfully, we don't have many hills where I live as it always seems someone is stopped behind me as close as they can get! So there's no margin for rollback errors without hitting someone!
When I learned to shift gears, I never was taught to use the handbrake. That's only used when parked.
DebbyM46227 is offline   Reply With Quote
New Yaris 5 DR HB arriving April 5, 2010 mkorejwo New YARIS Purchase Forum 6 04-06-2010 11:39 PM
ZPIracing Yaris Clutches ZPIracing Sponsors Classifieds Area 2 02-24-2007 04:50 PM
