Old 01-24-2013, 03:10 AM   #1
DJPaneno
Drives: 07 Yaris Sedan
You basically bolt these on, and the output on these are really good.
http://www.theretrofitsource.com/pro...roducts_id=227
You can tack on a halo option if you wish from the drop down options selection.
So, if I am seeing this correctly, it is a kit, so I would be doing my own retrofitting with this. I really am not proficient in working with cars, and doing a retrofit seems out of my league at this point.
On this site will they do the retrofitting for you and ship it in the housing, ready to go, or is this as I'm seeing it - a kit?
Besides eBay projectors, which I don't plan on ever gambling with, is retrofitting the other option at this point?
DJPaneno is offline   Reply With Quote
Old 01-24-2013, 04:13 AM   #2
Yes, this is a kit. But it's a bolt on kit. You basically just have to open your headlight (take off the lens from the headlight), remove that middle piece (the piece the shields the front of the light bulb and helps reduce glare), bolt on the projector, aim to make sure the cut off is horizontal, and tighten. Then put the headlight lens back on.
If not, you can use one of TRS recommended retrofitters, http://www.theretrofitsource.com/rec...trofitters.php. The nearest one to San Diego would be
Petro Auto Care
Spring Valley, CA 91977
jorge@petroautocare.com
Old 01-24-2013, 10:34 PM   #3
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I recently swapped out my hids for 90/100 halogens with a relay pack. The light output is amazing. No need to do anything else. Stock housings produce an excellent and effecient beam pattern with outstanding cutoff on low beams and highbeams that will blow your eye brows off.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Tags
projector headlights
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
CF vinyl roof, Spyder LED tails, whole car repainted 4x4Dragon Cosmetic Modifications (Exterior/Interior) 6 05-14-2012 11:39 PM
Canadians with Spyder Halo Projector Lights SeriousBlack Canada 13 11-29-2011 08:04 AM
