★weeaboo★
You're welcome!
That's what I had gotten too, though I went with the bixenon H1s instead of the DS2s since I didn't have any existing HID equipment already. Out of curiosity what shrouds did you get for your projectors? |
![]() ![]() ![]() Drives: Yaris SR '12 Join Date: Jan 2013
I'm hoping my existing HID kit stands up to the standard of the stuff from TRS now! If not it'll be another long wait for some ballasts :)
I got the bullet shrouds if I remember rightly. I wanted to cover most of the reflector up as possible. Hope they look OK! |
★weeaboo★
Oh yeah you'll be fine. I went with the Iris shrouds which are very shallow but wide as I wanted a clean OEM look. Our headlights are pretty deep so you can't see the projector bowl even though it's exposed because of how far back it sits in the headlight.
![]() FYI don't do what you see there and not paint the reflector bowl. I opted not to because I wanted it to look OEM. It's been mentioned with other projector retrofits that there is some light scattering out the sides from light bouncing off the reflector and it's true. It's not enough to blind anyone beside you but it's obnoxious when going down unlit roads and lighting up the trees in each upper corner of your field of view. I drive in the city 90% of the time and I don't even notice it unless I'm on an unlit street. |
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
i had to use epoxy on the subaru as if i changed the bulb the whole unit shifted... so i recommend it just so there is no chance of that happening. make sure you get the black headlight sealers for the back from TRS as well because you will have a large gap for moisture where the bulb socket is.
there were my 2 kits and some pics along the way. and these are the Morimoto D2S original. running 55W 5000k ![]() ![]() ![]() ![]() ![]() ![]()
That's a great looking retro there :) see, I have the new shape yaris, so I know the reflectors are a different type. I have HIDs installed at the moment - 6000k with no projectors, there is a small amount of light scatter to the sides but not a huge amount.
There is something that looks like a shield at the side of the headlight too so maybe that will help cut out some of the scatter. The shrouds I bought I am hoping cover enough that there won't be any light scatter but is it advisable to paint the reflector then? |
By black headlight sealers, I'm hoping you mean ones that might come with the kit I ordered, if not, it's gonna be another loooong wait to start this :(
But guys I can't thank you enough for your replies on this so far, they've all been a massive help. So thank you all once again! What's the best brand / type of epoxy to use for this? There's bound to be some name differences since I'm coming from the other side of the pond. |
It's here! The parts are finally here :) Slow UK customs! Very much looking forward to getting this going.
Can I just ask a couple of questions regarding aligning? I believe I have the H4 adaptor plates with the projectors, when I come to refitting the headlight unit, how reliable are these keeping the projectors straight? Any tweaking needed when getting that straight line cut off? Thanks. |
Awesome!
they are alright, you do still have room to adjust them side to side, and yes you will have to to make it perfect. That headlight sealer piece is new and never came with my kits so that awesome if you have those, reduce moisture from entering the assembly.
take lots of pics along the way. let me know if you need advice. oh! and go get some tinfoil tape! and wrap up the projector around the sides to prevent stray light from escaping! unless you want your headlight assembly to glow. you can kind of see it in my second picture. |
Thanks for the tips. I'll go ahead and get some foil tape. I had a test today with the shroud around the projector with a light inside just to check the cut off and not much scatter seemed to be present. So just foil around the projector where it's all open?
I'll make sure to take as many photos as possible. I'm in the last stages of getting is underway now. Need to find out if my radio will need recoding as I'm going to disconnect the battery, unless its safe to do whilst connected? Then I have to wait for a whole day of great weather as I don't k is how long it'll take me and in the UK at the moment good weather is hard to come by! |
#10 | |
Awesome!
That's great. I'll do that to avoid glowing. I'll cover all areas and see if I'll need to recode my radio if I do disconnect the battery. There's nothing in my owners manual to say it will need it, just that all preset stations will be lost. Seems fair enough and I don't mind redoing those, I just don't want it to screw up my sat-nav. I'll hopefully get some photos up soon of progress, like I say I'm just waiting for some good weather. I'll get started on the foil around the projector though. And get hold of some epoxy for fitting and some silicone for the shroud.
Great start - by my measurements it doesn't seem my lights will fit in my oven. Crap :(
What's the alternative do peeling apart the headlights then? Also, I have the H4 adaptor plates, unless I haven't looked at them at the right angle it seems though the projectors are going to be slightly tilted if I use the plate - roughly 10 to 20 degrees off so the light cut off will not be dead straight. If this is the case any pointers on how to alter this to have them straight? Thanks! |
Awesome!
alternative to oven is a heat gun, i,ve never done it this way but all you need to do it melt the glue,
#14 |
Thanks again, sorry for the delay, I'd been away. Got the headlights out and began heating with the heat gun. I can't seem to fine where the lens peels away from the housing itself. I've had the heat on it for about 4 minutes all around and it does not seem to budge. The glue looks like it's just cracking and not becoming pliable. Can anyone help at all? I don't want to hack away at the lights and ruin where they're sealed. I've got a few photos - hopefully they help.
#15 |
![]() Front of the light just under the projector. ![]() Same again ![]() Looking from the back of the light at the top. Hope these help. Can anyone see where it would separate and the best place to heat? Thanks all. |
#16 |
Anything guys?
I'm struggling with this. I know that as soon as I get it open I'll be ok fitting it. Would really love to get this going :) |
#17 | |
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
Neighbors oven?
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
#18 | |
Thanks for the reply. Same problem - just too small. Ovens seem to be wide enough to fit them, just not deep as the back of the headlight goes way further than originally anticipated. They are deceivingly large! |
| Tags |
| hid, projector, retrofit, yaris sr |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 07:10 AM |
| Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c | Yar Is Word | Third Gen Yaris General Discussion | 27 | 09-07-2012 12:37 AM |
| Vacationed in Italy - Brought home a D4D diesel Yaris | CTScott | Photo-Video-Media Gallery | 19 | 07-26-2012 04:13 AM |
