Old 01-25-2013, 01:06 AM   #1
Far out
Drives: Yaris
Originally Posted by Jassa123 View Post
Hello all, i am very excited to say i just fixed the water leaking from under the dashboard on the passenger side. I called up toyota 2 days ago with my problem and was told it would be an all day job and they would have to remove my dashboard (would cost around $400) They said my air con was blocked and was causing all the water to leak into my heater box and then run onto the floor. Well i thought that sounded like BS and so decided to google the problem and found many people with the same issue. The solution is simple.
Under the dash on the passenger side, pull back the flap of carpet a little bit and on the right hand side, down low, there is a little black soft tube that is leading to the outside of the car. Just pull on it and it will easily pop out. Dont worry it will pop back in afterwards. Then get a stick or something flexible and stick it up the tube being gentle. Water will run out when you have unblocked it. then plug it back in and the problem is fixed. No more water on your floor. I am a 28 year old girl with no expereince in cars and i fixed it so dont go to Toyota for this problem and save yourself $400. Good luck everyone. Hope this helps all with the same annoying problem. :)
How was the carpet held down, when I try to pull back, it was very restricted. I did not go any further from here. Was it velcroed? Thanks.
Far out is offline   Reply With Quote
Old 01-25-2013, 06:29 AM   #2
There is a piece of velcro that holds the corner in place. You only have to pull it back a couple of inches to access the hose.
Air Conditioner kick-in?? churp General Yaris / Vitz Discussion 5 05-26-2007 08:43 AM
Air Conditioner Noise Cathy General Yaris / Vitz Discussion 16 05-08-2007 02:08 AM
Air Flow switch problem aucorium DIY / Maintenance / Service 5 01-15-2007 04:54 PM
1.3 Ltr Yaris Air Filter mods aucorium Performance Modifications 9 08-18-2006 08:32 AM
