Old 01-25-2013, 08:11 PM   #1
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Looks like I will be getting a micro image fog light kit......Toyota fog kit is warranty replace only. PLUS get this: parts department showed me on screen that mid level LE trim does not/can not have fog lights installed from factory or aftermarket.....lmao......he sighed and laughed too, as that is what the screen inventory stated.....
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 02-23-2013, 01:04 PM   #2
oohcory
Oohcory
Drives: 12' Yaris 2dr Liftback
Send a message via AIM to oohcory
has anyone with a 12' LE tried installing aftermarket fogs?
oohcory is offline   Reply With Quote
Old 02-23-2013, 02:15 PM   #3
Yes. Besides Absolutely_Red, a few others have as well.
Old 02-23-2013, 10:50 PM   #4
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
All that is needed from the kits, are the lamps, fillers, and switch.
2012s have the wiring preinstalled.
As CTSott mentioned, the relay is integrated into the BCM.
You dont even need a switch!! If you want the fogs to always be on with the headlamps.
The lamps, if anyone is interested, are Camry interchange part numbers!!
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
2012 Fog Light Kits TimmyTwo2 Third Gen Yaris General Discussion 4 10-06-2014 03:41 PM
2012 Fog lights FIY Absolutely Red 12 Third Gen Yaris General Discussion 1 09-17-2012 10:31 PM
2012 Yaris LB Fog Lights TimmyTwo2 Cosmetic Modifications (Exterior/Interior) 6 03-21-2012 04:54 PM
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 11:12 AM
