Old 01-28-2013, 01:20 PM   #1
CoryM
Drives: 2009 5-door, 5-speed
For that amount it is probably just the free-play in the strut to knuckle bolts. Loosen the two bolts on the passenger side, then push inwards on the strut. It should tilt in, giving you more negative camber on the passenger side. Since you are lowered etc I assume you won't mind a little more negative camber than stock. This can also be done at the alignment shop, but most places likely won't do it as part of a regular alignment (I do if I think it is required).
It is a good idea to always push in on both sides when you do struts. This way you *should* have even camber side to side.
Cheers.
PS: make sure that the weight is off the strut when you loosen the bolts. Otherwise you won't be able to move it. Should be jacked under the frame/body
Old 01-28-2013, 02:11 PM   #2
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
Cheers.
^^^ This
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 01-28-2013, 02:55 PM   #3
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Load the driver side strut using a jack prior to tightening
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
Alternator Bearing barryware DIY / Maintenance / Service 7 11-23-2013 06:33 PM
"Parmas" Motor Parmas Forced Induction Forum 511 12-01-2011 08:00 PM
DIY Cellphone Car mount Arkhangel DIY / Maintenance / Service 3 08-24-2010 03:37 PM
DIY Camera Mount -- No Cost Version KCALB SIRAY DIY / Maintenance / Service 20 06-08-2009 03:12 PM
