Shocks upgrade
Want to upgrade the rear shocks from stock. I looked a for while on the forum and found really only the Monroe Sensa Trac and Tokico shocks being used.
If I am looking to install a rear sway bar at the same time as upgrading the rear shocks, what do you suggest for the shocks? Please advise...thanks, Pat |
![]() ![]() ![]() ![]() Drives: 2010 Yaris S Join Date: Apr 2010
Tokico,Monroe is a inferior product
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 |
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
If you wait a bit, megan is supposed to be releasing some stock replacement shocks, I tested them and was very surprised on how well they performed. Otherwise I'd say find a set of rear HTS's or blues.
#5 | |
So these KYB will work?
So these would work for the rear?
I only want to do the rear at this time. http://www.amazon.com/KYB-343442-GR-...1&s=automotive Quote:
This should be moved to the wheels and suspension section.
OP, I'd suggest doing all four at the same time. I installed my TRD struts up front, and left the rear OEM since we couldn't figure out how to get to the top rear shock nut at the time, and man, my car handled pretty bad. Once the rear TRD shocks were on, my car handled so much better. |
#7 | |
Thanks Koatic.
I plan to do the rear first since there is less action back there, and a sway bar. I will get to the front shortly thereafter, but retain the stock springs. Quote:
I'll price match on the rears, but the GR2 is not much of an upgrade in terms of performance (meaning you won't feel much difference). If you want a performance shock, you'd want Tokico blues. I can sell just rear pairs.
#9 | |
I'm not sure what you thought you were feeling with them, but there should be no actual performance improvement with this product.
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
Buy all 4 Tokicos and the rear sway bar at once from Garm at Micro Image!!
Garm, make him a deal!!
Cheapest DD I could find!! |
![]() ![]() ![]() Drives: 08Yaris2D, 88LandCruiser. Join Date: Jan 2013
#12 | |
vadr45
Drives: 2009 Base 3-door Join Date: Feb 2012
vadr45 Alexandria, VA 2009 Black Base 3-Door Yaris 1950 Austin A70 Hampshire |
Yeah, already put on Eibach's and Tokico reds and TRD sway. Much better now...an then some. Just trying to decide now whether the Eibach's get me low enough.
#14 |
#15 |
How long ago did you install the springs? If it wasn't too long ago, then they'll still settle and drop a little bit more. However, Eibach's drop is, what, 1.1" or 1.5"? I forget.
| Tein S-tech Springs with Stock shocks combination. | daddz07 | California | 11 | 08-21-2010 01:49 PM |
| Tein S-tech over Stock shocks | daddz07 | General Yaris / Vitz Discussion | 0 | 08-10-2010 10:48 AM |
| Tein S-tech Springs with Stock shocks combination. | daddz07 | Performance Modifications | 1 | 08-09-2010 03:45 PM |
| front shocks independent from rear shocks? | ammophobia | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 02-04-2010 11:34 PM |
| Shocks upgrade??? | CASTREX | Performance Modifications | 24 | 01-29-2007 01:13 PM |
