Old 02-01-2013, 01:39 AM   #1
JoshP82
Drives: Toyota Yaris
hi there every one anybodyb know how to take the bottom half of the air box out, so I can have a proper look.
JoshP82 is offline   Reply With Quote
Old 02-01-2013, 06:20 AM   #2
To remove the bottom of the airbox you have to remove the entire dashboard, the metal support for the dash, and then the airbox itself. It may be easier to go into the air intake for the fan with an inspection camera if you want to take a look.
Old 02-07-2013, 10:50 AM   #3
mudslingerdude
Drives: Toyota Yaris 05
Hi, ive been reading this thread as I too have an issue with water in the passenger side floorwell front and back. I am not sure if it is my AC unit as over here in the UK we rarley use aircon and my outlet drain hose looks to be clear. I have had a piece of stiff wire in the hose and it went up to the AC unit without much resistance. I wasnt sure how far to force the wire as i am not sure if I will damage something.
Also my air blows with quite a bit of force through the drain pipe when the heater is on so I am asuming the drain hose is not blocked.
The amount of water that is coming into the passenger side of the car is quite a bit, I often have a good half inch in the rear passenger well. I am suspecting its rain coming in somewhere!!!
Does anybody know any suspect places for water to get in on the 2005 Yaris models?
Thanks for your help on this one.
Mud
mudslingerdude is offline   Reply With Quote
Air Conditioner kick-in?? churp General Yaris / Vitz Discussion 5 05-26-2007 08:43 AM
Air Conditioner Noise Cathy General Yaris / Vitz Discussion 16 05-08-2007 02:08 AM
Air Flow switch problem aucorium DIY / Maintenance / Service 5 01-15-2007 04:54 PM
1.3 Ltr Yaris Air Filter mods aucorium Performance Modifications 9 08-18-2006 08:32 AM
