Old 02-07-2013, 12:30 PM   #1
Focus_Sh1ft
Focus_Sh1ft's Avatar
^ Lol. Your compression says otherwise though.
I've taken it apart and can't really figure out what's going on. My guess, since it was leaking past the valve, is that it wasn't sealing properly under normal operation. Kinking the reference line must have made it operate in reverse and force the valve closed. Maybe the spring is worn? I'm going to try shimming it before completely replacing it since I can use the Zage bov in the meanwhile.
Still can't believe the hell I've been through for something so simple. I'm especially bitter about bovs now because I also had trouble with the one in my tc lol
Old 02-08-2013, 05:55 PM   #2
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Just needs a stronger spring. Tial ones you can select spring , Greddy can be adjusted , TurboXS you shim. Some BOV's are used for supercharged applications and require it to be open at idle ( to bypass excess air driven by supercharger). In a draw through MAF sensor application if the BOV is cracked open, the car will run like poop because of unmetered air entering the engine .
Ptuning.com
Blown_xa is offline   Reply With Quote
FS: Autometer Cobalt 6170 Boost Gauge Nexus1155 Items for Sale by private party 2 02-02-2011 04:08 PM
Multiple cylinder misfire under boost LtNoogie Forced Induction Forum 13 11-02-2009 04:44 AM
Fill up with Super before starting your boost project LtNoogie Forced Induction Forum 5 12-01-2008 06:41 PM
Supercharger Selection and Limiting Boost Nexus1155 Forced Induction Forum 1 12-01-2008 03:51 PM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 02:42 PM
