![]() Drives: Yaris Join Date: Jan 2011
Thanks for the reply it is a digital diplay on a 1999 yaris.
OK. With the digital one, it could be a problem with the VFD (Vacuum Fluorescent Display) or its driving circuitry.
The pictures below show the inside of a 2006-2011 one, but I suspect that the first gen one is similar. The speedometer portion of the display is connected to the main circuit board via a ribbon cable. The cable connection may be loose causing the intermittent behavior. You can pull the trim off around the instrument cluster to then remove the assembly. Digital Cluster - Open.jpg Digital Cluster - Connector.jpg
